Write Data to Table Skill Execution from Action Flow
  • Aug 1, 2023 8:35 AM UTC
  • 131 views
Good morning,
I'm trying to use the Write Data to Table Skill from an Action Flow, but I keep getting this error:
 imageAs you can see in the INPUT section, the action flow is providing the required Data to the Skill, so I do not understand what is going on..?
The skill itself is quite simple, with a Manual Sensor asking for User Input for Table Name, Column Name and Column Value
And the Write Data to Table action is configured as follows, ensuring correct Data Types:
 imageWhen I query my database, the column is indeed a Float Data Type:
So I am lost as to what is going on, can you please provide some support ASAP? Thank you very much!
  • Aug 1, 2023 9:06 AM UTC
Hi @vasco.caron11 ,
I tried to implement the same Skill but without specifying the toString() function for the Table_name and Column_name because they are already as Strings identified and it worked fine
I hope that works fine
