Workday calendar isn't working in Studio Analysis
  • Jul 13, 2022 8:06 AM UTC
  • 6 replies
  • 230 views
I have a client calendar with their working days uploaded to my data model in a SAP TFACS format.
This TFACS table is also added to the model but not connected to any other table.
I have done a complete reload properly already.
When I go to my analysis and see the throughput time, it didn't change, even if I put all the working days to "0" in the TFACS table. It seems that isn't tacking into account my calendar.
How can make it works in my analysis? Do I have to use functions to make the analysis use the new schedule?
Many Thanks,
Paula.
Best answer by Anonymous
Hi @paula.garci11 ,
are you using something like this when you're calculating the tpt?
REMAP_TIMESTAMPS (
"TimestampTable"."Timestamp" ,
DAYS ,
WORKDAY_CALENDAR ( "TFACS" ) ,
"TFACS"."Ident"
https://docs.celonis.com/en/workday_calendar.html
  • Answer
  • Jul 13, 2022 8:42 AM UTC
Hi @paula.garci11 ,
REMAP_TIMESTAMPS (
DAYS ,
"TFACS"."Ident"
  • Jul 13, 2022 9:54 AM UTC
Hi @1460067637,
I added your formula but it gives me the next error:
Do I have to put a timestamp field in my TFCAS table?
Many thanks for your help!
Paula
  • Jul 13, 2022 11:33 AM UTC
Hi @1460067637,
Paula
I believe you will need to connect your tables in the data model @paula.garci11
  • Jul 13, 2022 11:50 AM UTC
Yes, but if the TFACS table have the format 1001... I do not have any field with timestamp.
If I make other kind of table with dates and hours it wouldn't be TFACS format that is required to connect the calendar with the datamodel, isn't it?
Thank you @1460067637
  • Jul 13, 2022 1:12 PM UTC
@1460067637 I solved it. I put just 'BAY' instead of the "TFACS"."Ident" field.
Many thanks for you help!
  • Jul 13, 2022 1:14 PM UTC
Amazing! Happy I could help :)
