Workaround to copy Action Flow over realm
  • Jan 5, 2022 5:42 AM UTC
  • 51 views
Dear folks,
I created Action Flow in my training environment and would like to copy to other environment in eu-1 realm (different realm).
I tried Content-CLI to pull and push it via zip files. Push program was done successfully but copied program had 403 error when clicking it.
I confirmed Action Flow works fine if two environments have same realm.
Do you have something workaround to copy Action flow over realm ?
Kazuhiko
I found Blueprint option in action flow menu, that can manually export my action flow to json file, and it can be impoted to any realm.blueprint
