Why I am getting Error: No common table could be found in S4HANA starter kit although I am using Celonis standard transformation and model.
  • Nov 28, 2023 7:58 AM UTC
  • 153 views
I am getting below error in Knowledge Model ->Records->Transaction Activities. Although I have joined both the tables BSEG and _CEL_AR_ACTIVITIES in data model, using key columns
Join
TransactionActivityJoin
  • Nov 28, 2023 1:04 PM UTC
I would suggest an alias of the same name to the Activity table. Check the variable VAR_ACTIVITY_TABLE 's value and use that name as an alias in the data model.
  • Nov 28, 2023 1:36 PM UTC
Hi, Thanks for your quick response! I have checked the value of variable “_ VAR_ACTIVITY_TABLE” and the activity table name both are same. Please see the Screenshot attached. Can you suggest any other solution? Variable [cid:image001.png@01DA222D.3B5C5330] Table Name [cid:image002.png@01DA222E.0447B820] Thanks, Bhupendra
