Why does the Automation Rate with time dimension Eventtime change ex post?
  • Jun 21, 2023 7:48 AM UTC
  • 144 views
silke.norri
Level 1
Hi all, we report the Automation Rate with Eventtime as time dimension.
We were expecting, that the Automation Rate therefore should be stable e. g. for the past year 2022 regardless whether we extract the data in March or in June. Unfortunately we have changes even though we did not change the measurement.
We have deviations in the number of activities as well as the number of cases.
Formula:
AVG(CASE WHEN "_CEL_O2C_ACTIVITIES"."ACTIVITY_<%= language %>" IN
(<%= whitelist %>)
THEN
NULL
WHEN ISNULL( "_CEL_O2C_ACTIVITIES"."USER_TYPE") = 1
THEN
NULL
WHEN "_CEL_O2C_ACTIVITIES"."USER_TYPE" IN (<%= auto_user_type %>)
THEN 1.0 ELSE 0.0
END)
Remark: We have not changed the whitelisted activities nor the user types included in the variable auto_user_type.
Any ideas? Thanks in advance
  • Jun 22, 2023 12:58 PM UTC
Hi Silke,
could you please provide me with the Formula of the dimension Eventtime? I assume maybe it is a Problem of referencing the wrong Eventtime, which could distort the automation rate
silke.norri
Level 1
  • Level 1
  • Jun 22, 2023 1:06 PM UTC
Hello Rashid,
the formula is ROUND_MONTH("_CEL_O2C_ACTIVITIES"."EVENTTIME")
It is a column of the activities table.
imageView from the attribute selection:
imageThanks
Silke
  • Jun 22, 2023 1:28 PM UTC
Hello Rashid,
imageThanks
Silke
Hello Silke,
thanks!
The Problem with this Formula is, when we have a case that has some activities in one month (that don't have the automation criteria you provided: probably end of a month) and the rest on an another month(which have the automation criteria:probably beginning of a month) so celonis get the eventtime of the false activitiy (first part).
Solution: Try this PQL instead:
ROUND_MONTH(TIMESTAMP_COLUMN ( CASE WHEN
Condition 1 when is automated
AND
Condition 2 when is automated
THEN
"ACTIVITY_TABLE"."EVENTTIME" END ) )
I hope that helps :)
