why does Celonis use Snowflake schema instead of Star schema?
  • Sep 3, 2023 6:39 PM UTC
  • 102 views
  • Sep 4, 2023 9:23 AM UTC
A snowflake schema is a type of database schema that is used to store data in a more complex format than the star schema.
Personaly, I like transform the complex data in a star schema, because is more simple for understand and has more performance.
But, sometimes is not possible to do this, for exemple in cases that data transformations needs a lot of processing to joint the data. Then, a way can be use the snowsflake.
