Where to download on-pre Agent for Data Extraction
  • Feb 11, 2022 7:33 PM UTC
  • 71 views
Forum|alt.badge.img+14
recently, we have been registered as a partner. Where can I download the on-prem agent for the data extraction of an on-prem system?
best regards
I dug my way through some sites and guides like these below - it seems to be not available publicly -the best would be ask Celonis for on-prem agent files.
https://support.celonis.de/display/CPM46/Installation+guide
https://help.sap.com/viewer/product/SAP_PROCESS_MINING_BY_CELONIS/4.6/en-US
Screenshot 2022-02-11 at 20-40-21 Installation guide - SAP Process Mining by Celonis 4 6 - SAP Process Mining by Celonis
Mateusz Dudek
Forum|alt.badge.img+9
You can also check the help on your instance. Some links are also there, and are based on the access that you have been provided.
