Where can I find Revert to Base KM functionality in Extension Knowledge model?https://docs.celonis.com/en/knowledge-model.htmlHow it works in practice and where I can find it?
  • Nov 16, 2022 1:25 PM UTC
  • 205 views
Screen from Docs
Once you go to your KM, select anything in the example I am selecting the record, you will see an option at the top right
abhishek.chatu14
  • Nov 18, 2022 8:16 AM UTC
Thank you!
I thought that Revert to Base works quite different.
I think that when you create any new object, then you can revert it to base. Not anly updating existing object, that already is in BASE KM.
