When I try to use the 'Upload Files' option in the 'Add Data Connection' screen, I end up seeing a dialog box with a loading icon. I am not able to get past it.Can someone help me to understand why this is happening and how to solve it?
  • Apr 28, 2023 2:12 PM UTC
  • 97 views
Output after clicking on optionOption that I click
  • Level 0
  • May 1, 2023 11:33 PM UTC
Dear Omraan,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly help you.
Thank you in advance.
