What will be the cause for the SSLHandshakeException while connecting the Uplink?
  • Jul 4, 2021 7:52 AM UTC
  • 137 views
[uplink-thread-1] c.celonis.uplink.manager.UplinkManager  : Uplink could not connect: 'I/O error on POST request for "https://XXXX.celonis.cloud/uplink/api/public/uplink": Remote host terminated the handshake; nested exception is javax.net.ssl.SSLHandshakeException: Remote host terminated the handshake', waiting 13000ms before retrying --EOM--
Hi @shritej.thorv11,
as this seems to be an individual error, could you please reach out to Servicedesk? We require some further information on your instance to solve that issue.
Justin
gabriel.okaba11
Hi Shritej,
we would require some further info and troubleshooting sessions since this could have many different causes. Hence, Servicedesk is the best for this type of inquiry.You can try to troubleshoot it on your own if it is an issue with the cert
celonis.cloud/help/display/CIBC/Fixing+%27unable+to+find+valid+certification+path%27+errors
Gabriel
  • Oct 10, 2022 1:46 PM UTC
Hi All,
I'm also facing the same Issue, Any help from your end would be great since you've already faced this Issue.
While executing in CMD : java -Dloader.path=jar -Dspring.config.location=application-local.yml -jar connector-jdbc.jar.
I'm getting the below error,
ERROR Message : javax.net.ssl.SSLHandshakeException.
Thanks in advanced.
Sudharsan V
