What standard does Celonis use for JSON calls via API?
  • Jan 15, 2024 8:03 PM UTC
  • 68 views
Can you help us with a question, please?
What standard does Celonis use for JSON calls via API? RAW or X-www-form-urlencoded?
Could you cite examples of these configurations within Action Flows?
Thanks
Forum|alt.badge.img+5
Thanks for posting. The content-type of body is selectable to your configuration. An example of the Action Flow module can be found in the following document. https://docs.celonis.com/en/http--action-flow-.html If your focus point is different from your expectation, please open a support call with a detailed scenario.
