What's your best practice?
  • Oct 5, 2022 1:49 PM UTC
  • 176 views
All, I am asking some basic question to see if experts are doing something different.
Question 1) Consider a P2P Process - Do you take PO -OR- PO-Line items while building case key (I take Line item by the way)
2) Date filters - Do you use creation date as standard filter or you change it depending on use case, For example, I take PO creation date for generic overview of analysis but for "rework" I take date of rework in rework analysis sheet.
What's you view?
Regards,
  • Oct 6, 2022 9:28 AM UTC
A) There's no best practice - usually it's up to client how detailed process and data he wants to see - usually it's easier to aggregate the do the opposite.
B) That date should be changed depending on the use case, sometimes multiple dates are used in single KPI/formula
Mateusz Dudek
  • Nov 1, 2022 5:31 PM UTC
Mateusz Dudek
Thanks Mateusz. It helps :)
