What is the meaning behind the difference in figures in Variant explorer
  • Aug 23, 2021 9:21 PM UTC
  • 5 replies
  • 68 views
Forum|alt.badge.img+7
The screenshot with the red circles is filtered on Avg throughput time and the screenshot with blue circle is filtered on median throughput time. If you some up the values in the explorer (Example: Red circle image:- 4 + 20 + 13 = 37) it is not equal to the median red circled day of 66.5 . Th difference also exists when I filter on median throughput time. Any suggestions?
Update (NOT AN ANSWER): When I dived deep into the variant explorer and the global filters applied to it the main filter that fails is the activity selection one (for a particular stage reason). For example: If filter this variant explorer to go through the 'Awaiting Back-up from Customer' stage reason the median value for the variants in the right hand paretto (66.5) does not add up to the total throughput days spent throughout the process for that variant.
I would really appreciate some suggestions
  • Level 6
  • Sep 2, 2021 6:21 PM UTC
Hi, @mohamed.ruzli.moham
I'm not 100% sure if this is the answer, but since no-one answered, I'll risk it!
Maybe it has to do with the number of times the activity 'Awaiting Back-up from Customer'  is repeated. What the Variant Explorer is telling you is that the Avg Throughput time between 2 consecutive occurences is 14 days, but it doesn't say how many times it was repeated... Your calculation would be right if there were only 1 repetition.
That it why the total throughput time of the variant is higher than that sum.
See you!
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Sep 13, 2021 12:47 PM UTC
See you!
I believe @1460047871  is on the right track.
When you select this variant and filter the dashboard to only show this variant, you could inspect some cases to see how often this is repeated (and since it's 1 variant, all cases will have the same number of repetitions).
Hope this helps!
Forum|alt.badge.img+12
I am with you @1460047871
Awaiting Back-up from Customer'  is a rework kind of activity here.
And the avg throughput time here is 14 days but since there is a loop on that activity so it doesn't say how many times it was repeated..
Hope this helps!
  • Sep 21, 2021 5:32 PM UTC
I am with you @Rui Bebiano
Hope this helps!
