What is the difference between an eventlog and digital footprint?
  • Feb 23, 2023 1:01 PM UTC
  • 217 views
As @jain.saksh already explained: the event log is the data set where all digital footprints are stored. If you see it as a table, then a digital footprint is a row in the event log table, being a combination of Case ID, Activity Name and Timestamp (and optionally other attributes).
  • Level 1
  • Feb 23, 2023 1:39 PM UTC
This digital footprint will consist mostly out of a timestamp, an activity name and a case ID. This data is all captured and can be found in the Event Log, which is a record of everything that takes place in order to perform a task. Event Collection will thus bring all the event log data from every operational system in an organization together so it can be analyzed for process performance
  • Feb 23, 2023 1:49 PM UTC
Thank you Jain for your explanation. It seems they are the same thing but I still couldnt get the difference.
Forum|alt.badge.img+28
  • Feb 24, 2023 1:03 PM UTC
Okay, now I get it.
