What is 'Converted' about NETWR_CONVERTED
  • Aug 9, 2022 4:42 PM UTC
  • 69 views
Is it USD to EURO? Other way around?
  • Level 0
  • Aug 18, 2022 1:23 PM UTC
Hi Anjola, It depends on Your configurations, of course, You can check the parameters in the Data Integration - Data Pool Parameters. There You can see to which currency is the original currency being converted. Per default it is to EUR. If You still want to use Your original values, You can do so by using the NETWR column, however this would be an issue if You have multiple currencies set as Your raw data, as You would have multiple currencies adding up.
Hope this answer helped
