Whai celonis infterface ? And to connect celonis Interface with client ERP system ?
  • Sep 27, 2021 7:34 AM UTC
  • 127 views
Hey Srijan,
I believe you want to know how to connect celonis to client ERP, here are the steps-
  1. Identify Data Sources: Determine which data sources within the ERP system contain the relevant event logs or transactional data that you want to analyze using Celonis.
  2. Data Extraction: Extract the necessary data from the ERP system. This might involve using APIs provided by the ERP system, direct database connections, or data export functionalities within the ERP system.
  3. Data Transformation: Cleanse and transform the extracted data into a format compatible with Celonis. This might involve data cleansing, normalization, and restructuring to ensure consistency and accuracy.
  4. Data Loading: Load the transformed data into Celonis. Celonis supports various data loading mechanisms, including file uploads, direct database connections, and integrations with third-party data platforms.
  5. Data Model Configuration: Configure the data model within Celonis to define the relationships between different data entities and establish the context for process mining analysis.
  6. Visualization and Analysis: Once the data is loaded into Celonis, users can use the interface to visualize the processes, analyze process performance, identify bottlenecks, and discover opportunities for optimization.
  7. Automation and Integration: Depending on the requirements, you may set up automated data synchronization between the ERP system and Celonis to ensure that the analysis remains up-to-date. This can involve scheduling regular data imports or real-time data streaming.
  8. Security and Access Control: Ensure that proper security measures are in place to protect sensitive data, and configure access control to restrict access to the Celonis interface based on user roles and permissions.
Feel free to reach out, if you have any further doubts.
