want to read the file through machine learning, could you please help me
  • May 31, 2024 11:16 PM UTC
  • 108 views
muthappan.alaga
Level 8
Hi @sankarganesh.jayak12 ,
Can you please elaborate little more, what format of the file? are you planning to use it from Machine learning workbench using pycelonis?
Thanks
Muthappan
  • Jun 4, 2024 8:08 AM UTC
Hi Sankarganesh,
You can open file in machine learning workbench using python using the below code (nb: assuming your file is a text file).
#directory:  /home/imtiaz/code.py
text_file = open('file.txt','r')
#Another method using full location
text_file2 = open('/home/imtiaz/file.txt','r')
print('First Method')
print(text_file)
print('Second Method')
print(text_file2)
Thanks,
Akshay
