Views input-box with type number still considered a string on Javascript side
  • Nov 27, 2023 7:13 AM UTC
  • 197 views
joshua.asenh
Level 2
Forum|alt.badge.img+11
Hello there,
is it intended behavior/am I doing something wrong, that even with the type attribute for an input-box set to number, the variable will still be considered a string on javascript side once set to a value via the input box?
This of course results in the + operator behaving differently when performing calculations with javascript (see the example in the picture). While obvious in this case, as other operators will dynamically cast to int or float just fine and the default values work as intended before being changed by the variable input, it took more time than I'm willing to admit for me to understand, that this was the reason my annotation lines would sometimes not show up for my histogram.
Here the Yaml-code for the example:
metadata:
  key: variable-input-test
  template: false
  name: Variable Input test
  allowAdvancedFilters: true
variables:
  - id: Value1
    defaultValue: 1
    type: NUMBER
  - id: Value2
    defaultValue: 1
    type: NUMBER
layout:
  rows:
    - id: MainRow
      growHeight: true
      columns:
        - id: InputColumn
          layout:
            rows:
              - id: Value1InputRow
                columns:
                  - id: Value1InputColumn
                    componentId: Value1InputBox
                    order: 0
                order: 100
              - id: Value2InputRow
                columns:
                  - id: Value2InputColumn
                    componentId: Value2InputBox
                    order: 0
                order: 200
          order: 50
        - id: MainContentColumn
          componentId: text-box-ba2824cd-d084-41b1-9c4f-64ebf080ed4d
          type: default
          order: 100
      order: 100
components:
  - id: Value1InputBox
    type: input-box
    settings:
      placeholderText: ${Value1}
      type: number
      onChange:
        update:
          variables:
            - name: Value1
  - id: Value2InputBox
    type: input-box
    settings:
      type: number
      placeholderText: ${Value2}
      onChange:
        update:
          variables:
            - name: Value2
  - id: text-box-ba2824cd-d084-41b1-9c4f-64ebf080ed4d
    type: text-box
    settings:
      title: ""
      content: The "Math" of string addition says that ${Value1} + ${Value2} =
        ${Value1 + Value2}. The type of Value1 is ${typeof(Value1)}, the type of
        Value2 is ${typeof(Value2)}.
Joshua
abhishek.chatu14
I believe that the type is only for the input by the user, all variables in Celonis are of type string and hence will still be considered a string  on javascript side. As you are already using functions the same should help you with the desired calculations.
joshua.asenh
Level 2
  • Level 2
  • Nov 27, 2023 8:06 AM UTC
Well, the default values are passed "correctly" as a number, hence why it may work at first but break once the variable input is used.
And yeah, it can be fixed using function to cast the type or the "-" operator will work fine in general as well, it was just not how i expected it to behave.
On that note: does the the type attribute for variables do anything?
Both the documentation under https://docs.celonis.com/en/views-variables.html as well as the code snippet have them.image.png
