Views 2.0: same dashboard for multiple teams
  • May 17, 2024 1:32 PM UTC
  • 77 views
michael.kaemp
Level 5
I'm supposed to present the same dashboard to several teams. But: each team is only supposed to see their data (identifiable by an attribute). Note: I want to have something like a master view so that I have one single place to make changes, and I don't want to deploy future changes with a copy-paste approach to the team views.
Using legacy views I realized such scenarios by extending or embedding views from a master view as team views, setting predefined filters, and giving permissions on object level.
Carolin Ullrich
Hello Michael,
embedding views for reusability purposes (in the sense of a library of single or multiple components) will come later this year (H2).
Having said that, our first release will not allow for advanced parameterization (but only offering the options of a 100% reuse or loosing connection between the instances) but specifying different filters will be possible. I recorded your case but let me know if you are up for discussing this use case in more detail!
Caro
