Vertical (axis Y) position line in a chart from Process Analytics/Analysis
  • Nov 10, 2022 2:55 PM UTC
  • 224 views
andré.tafur
Level 8
Forum|alt.badge.img+19
Hi everyone,
I am trying to create a scatter pot with 2 position lines, one on the x-axis and one on the y-axis. I have created the horizontal line on the chart but have not been able to create the vertical line. Does anyone have any suggestions please?
Thanks for your help.
abhishek.chatu14
Why not use the scatter plot option in Celonis?
You can plot your x and y axis and then just define a grouping
imageYou can find more information on the following link
https://docs.celonis.com/en/charts-and-tables---settings.html#UUID-ad50c78f-fdba-2008-4377-f6f9555e3677_id_ChartsandtablesSettings-Scatterplotoptions
I may be missing something in your question.
andré.tafur
Level 8
  • Level 8
  • Nov 15, 2022 8:15 PM UTC
Dear Abhishek,
Thanks for your reply, we already using the options for the scatter plot, but only I can create a position line (the orange one) in the x axis and I need to create another position line in the y axis, here is my scatter plot:
imagePlease do you know how to do it?
Thank you for your help
abhishek.chatu14
Dear Abhishek,
Are you already using the Horizontal data series & Vertical data series ?
andré.tafur
Level 8
  • Level 8
  • Nov 17, 2022 7:29 PM UTC
Yes we are using it,
This is the actual configuration:
