Variables with PQL input in Knowledge Models and Views?
  • Aug 7, 2023 11:21 AM UTC
  • 186 views
javier.desar
Level 4
Hi everyone,
I am trying to set a Display Rule for a KPI List in a View in Studio.
I want to use the Display Rule to set the background color of the KPI based not on a fixed value, but rather on a dinamic input coming from a table in the data model.
I wanted to configure this input using PQL just as it is done with variables in a regular analysis, but I have not found such an option in Views or Knowledge Models.
I would want to know if it is possible to work in an analog way to an analysis in studio, defining a variable with input written in PQL, and then using such variable as a parameter in the Display Rule YAML code.
is that possible?
Thank you!!!
Best regards
Javier
abhishek.chatu14
The way you achieve this is by creating a Custom Object in the KM and assigning it to the KPI
Kindly find the following example for Custom Object
imageTo make it Dynamic you need to use a Runtime variable instead of value that you update, please note every time you change the runtime variable the page needs to be refreshed and runtime variable are represented between ${{}}
Hope this helps!
javier.desar
Level 4
  • Level 4
  • Aug 7, 2023 2:33 PM UTC
Hi Abhishek,
thank you for your answer.
I see the way you link the variable to the custom object and then the KPI itself.
It is yet not so clear for me how I can set the input for the variable with PQL and not just plain text.
I have seen for both Views Variables and Runtime Variables, that just plain text can be typed in as input, and I would need it to be a PQL statement.
