<%=VARIABLENAME%> is not working for me, I'm not sure why? Do I have to keep in mind which using it or are there any conditions to use it?
  • Aug 8, 2024 5:31 PM UTC
  • 165 views
Sverre Klein
Forum|alt.badge.img+13
Hi @kaushal.raval11,
I which setting are you using <%=VariableName%> ?
is it possible you can provide s creenshot of what you are trying to accomplish? Thanks!
  • Aug 8, 2024 10:08 PM UTC
Hii Sverre, thanks for responding.
When I use my already created variable with ${x} in the dimension editor field it gives me required result in my column, but when I use same in the title of that column it does not give me any value. For that reason, I way trying <%=VariableName%> for heading. My goal is to make it work in the heading only
@sverre.klein11
