Variable Clear
  • Mar 19, 2025 6:52 PM UTC
  • 169 views
douglas.souza
Level 5
Good afternoon/Good morning Celonautas, could any of you tell me if there is any way I can clear the variable? For example, the variable is disabled. I would like it to clear the variable from my dropdown when it is selected.
Here is how it looks when I disable it.
And how I would like it to look
jonas.hess
Level 7
Forum|alt.badge.img+3
  • Level 7
  • Apr 8, 2025 1:38 PM UTC
Maybe possible with a skill if your Dropdown is a real Variable and not like VBAP.VBELN.
Then you can say to the skill, if status is deactivated then variable x = ‘ ’
