Use same host for two different process's extractor.
  • Mar 22, 2022 6:46 AM UTC
  • 55 views
We have a O2C process and it is using a celonis data extractor agent to reach on-premise source system. Here is the question; We now going to implement a second process and it will also use an extractor. Can we use the same host to set up new extractor ? Or do we have to build a new one ?
Hi Omer, Please be informed that yes, you can use the same extractor server and uplink connection for sap systems. We don't have documentation about it but we have multiple clients that use this method. Thanks and regards, Doruntina
  • Level 7
  • Mar 30, 2022 7:06 AM UTC
Hi Doruntina,
Thank you for your answer. Sorry for the missing info. The second process that we will implement is a nonsap system process. It is written inhouse and running on web browser. It is using MS SQL and We shall connect to MS SQL via extractor.
Does it change something ?
Hi Doruntina,
Hi Ömer,
If your first process is SAP, and your second is SQL extractor, then you should have a new one.
