Unreliable Filter Extractions when using a mix of ANDs and ORs
  • Jan 5, 2023 10:21 PM UTC
  • 188 views
Like the title says, I'm trying to filter a BSEG extraction as follows:
(KOART = 'K' OR BUZID = 'Z' OR EBELN IS NOT NULL)
AND
(AUGDT >= <%=startDate%> OR AUGDT IS NULL)
In English:
One or more of the following 3 must be true:
  • Account Type (KOART) = 'K'
  • Line ID (BUZID) = 'Z'
  • PO Number (EBELN) IS NOT NULL
AND, One of the following 2 must be true:
  • Clearing Date (AUGDT)>= 2021.01.01 (startDate parameter)
  • Clearing Date (AUGDT) IS NULL
Screenshot:
Extraction Filters
However, when looking at the data, I'm not getting any cases where Clearing Date (AUGDT) is null
Extraction Data CheckWhereas, in a previous extraction that omitted AUGDT as a filter field, we have 50K+ Cases with a NULL AUGDT Field, and adhering to the other Filtering Conditions:
NULL AUGDT Example
Therefore I can only assume that there is something wrong with the way that the filtering works.....that OR should always include cases with a NULL AUGDT.
Not being able to use AUGDT as a filter is causing me to have to extract a gigantic amount of superfluous data (50 Million + Lines)
Any help is much appreciated!
Forum|alt.badge.img+28
Hi Vasco,
I would say that the syntax that you use is correct and should return a True/False.
What you could try is make the statement more explicit, by using ```ISNULL ( AUGDT ) = 1```, but that's a long shot.
  • Jan 12, 2023 9:21 AM UTC
Hi Vasco,
Hello Jan-peter, Unfortunately I don't think we can use ISNULL in the Extractor Filters: [image: image.png]
