UI Path Action Flow Integration: How to add input to UI Path Queue from json file (from Skill)?
  • Sep 1, 2023 11:58 AM UTC
  • 124 views
Hello Community,
I've created an Action Flow in Celonis which contains an UI Path Queue Item which gets data from a webhook item. The webhook item data comes from a Skill, which gets data from a Record of a View.
I couldn't figure out how to set up the "Add specific content" field of the UI Path Queue Item.
I am really thankful for your help!
The json Data file which comes from the Skill and goes into the webhook looks like this:
Forum|alt.badge.img+5
The following URL describes that the specific content should be the specific Key-Value pair to add the queue for UiPath. https://docs.celonis.com/en/uipath--action-flow-.html https://docs.uipath.com/orchestrator/reference/queue-items-requests You selected the mapping to {jsonData} and the jsonData seems to have Key-Value pair. It seems to be OK. If you have some errors in the execution of your action flow, please open a support ticket with the following information. - Full URL of the action flow - Blueprint of the action flow - Screenshot of the error message.
