UI Path Action Flow Add an Item to a Queue with error "RuntimeError [400] An organization unit is required for this action."
  • Jan 23, 2024 12:32 PM UTC
  • 74 views
Hello Community,
I've created an Action Flow in Celonis which contains an UI Path Component which Adds an Item to a Queue. WHen trying to test if I can actually add an Item to a test Queue I get the error "RuntimeError [400] An organization unit is required for this action."
The user I'm using has all the necessary roles and permissions to edit a queue.
Where can I define the Organization Unit Id?
1
Also, I tried using the "Make an API Call" with the Method Post and the URL "odata/Queues/UiPathODataSvc.AddQueueItem" but it gets the same error.
2
I am really thankful for your help!
Sverre Klein
Forum|alt.badge.img+13
Hi Bernardo,
I sadly only have experience with the UiPath Cloud connection type, not on-premise. If I create a connection using Uipath Cloud, I get the option to fill in the Uipath Organisation ID and this has been working fine for me.
I see that this is not an option for On-premise, which is in beta.
This is a very bold and dangerous assumption, but I think this might be bug (since it is in beta). However, I hope someone else might have a workaround or a solution for you who has experience with the on-premise connection.
In the meantime, I would advise Creating a support ticket.
