Triggering Action Flow from Analysis button
  • Nov 23, 2022 11:44 AM UTC
  • 251 views
Hi everyone,
I am pretty new to Action Flows and currently I am trying to trigger an Action Flow by clicking a button in one of my analyses. Is this technically even possible?
I couldn't find any fitting trigger modules in my Action FLow instance.
Thanks in advance
Fynn
Best answer by Anonymous
Hi Fynn,
Actually it is possible to trigger Action flow from analysis. However it's rather complicated.
In analysis instead of triggering AF you can trigger ML workbench Python Script. That script can trigger skill or action flow using so called "Web hooks".
Web hooks documentation for triggering skills: https://docs.celonis.com/en/webhook-catch-hook.html#UUID-01aa2a2e-d2f2-4b06-888b-e4492e5d42b6_id_WebhookCatchHook-WebhookCatchHook
Web hooks documentation for triggering AFs: https://docs.celonis.com/en/trigger-an-action-flow-from-ml-workbench.html
However with that there's specific problem: you can just trigger, and not send eny data (f.e. selected rows or filters). Business Views are offering much more possibilities to trigger and transfer data to skills which can trigger action flows.
According to Celosphere Celonis is working on replacing skills with action flows in future, however there's no roadmap or specific dates for that.
Mateusz Dudek
muthappan.alaga
Level 8
Hi Fynn,
Action flows are not possible from Analysis, only from views are possible, so try to create a view. Also check celonis marketplace for apps which have action flows.
Thanks
Muthappan
  • Answer
  • Nov 23, 2022 5:35 PM UTC
Hi Fynn,
Mateusz Dudek
  • Nov 29, 2022 6:30 PM UTC
Well, you can in a fast and dirty way without ML
You start the AF with a Webhook.
Create a button component in the analysis
Select "Open external link"
Put the Webhook URL there.
Done.
Of course, you can do the same with a skill starting with manual sensor and then a Execute Action flow
You put the url of the skill in the button
With skills you can pass info (in theory, I haven't tested)
In both ways a new tab is opened in your browser, it can be a bit confusing for an end-user
HTH
salma.zeped
Level 8
Forum|alt.badge.img+3
  • Level 8
  • Mar 29, 2023 12:21 PM UTC
Hi Fynn,
Thanks
Muthappan
Hi Muthappan,
Can you share how this can be triggered from Views?
