Trigger Python within an Action Flow
  • Mar 10, 2023 2:22 PM UTC
  • 104 views
Is there a simple way of triggering a Python script within an Action Flow?
Forum|alt.badge.img+5
Hi Pierre,
you could possibly use the Celonis Skill "Execute ML Notebook" to trigger a Python script. You just have to put the script into a Jupyter Notebook in the section Data -->Machine Learning. If you don't see the Machine Learning option, you have to create a support ticket to enable the feature for your team.
Best regards
