Transformation Center - I am trying to write a KPI in Transformation Center to monitor when "EBAN"."MATNR" (Material Number is Missing in Purchase Req) Can anyone provide some guidance
  • Feb 28, 2024 11:01 PM UTC
  • 15 replies
  • 200 views
Best answer by Sverre Klein
Thank You! I will try this. I appreciate your help
Hi @richanda.wrigh,
Yes this works as well! Weird that the IN predicator didn't work.
From your above filter statement with the IN predicator, I think you (and also me) used a curly quote (’) instead of a straight quote (') at the end of 0010009755.
Try this
FILTER "EBAN"."BADAT" > TO_DATE ('2024-02-23' ,FORMAT ( '%Y-%m-%d' )) AND "EBAN"."FLIEF" IN ('0010009689','0010007548','0010009755')
Let me if that worked :)
Sverre Klein
Sverre Klein
Forum|alt.badge.img+13
Hi @richanda.wrigh,
If I understand correctly, you only need help with Configuring the KPI right?
If you want to monitor how many times MATNR is missing, you can use COUNT with a CASE WHEN statement.
It would look like this:
COUNT(CASE WHEN "EBAN"."MATNR" IS NULL THEN 1 else 0 END)
This basically counts the amount of cases that miss a Purchase Req number.
Hopefully this helped you out. Otherwise, let us know if you need more help!
Sverre Klein
  • Feb 29, 2024 1:59 PM UTC
Hi @richanda.wrigh,
Sverre Klein
Sverre Klein
Hi @richanda.wrigh,
I hope it worked for you? Let me know! 😁
Forum|alt.badge.img+28
Hi @richanda.wrigh,
Sverre Klein
Small addition to this one: you should use ‘ "EBAN"."MATNR" IS NULL ‘ (= only works with real values). The other part should do!
bunyod.sap
Level 7
  • Level 7
  • Mar 2, 2024 12:28 PM UTC
Hi guys. I have a related question to the Transformation Center please. During calculation of the AVG why it will not take the weighted AVG? For instance in the above mentioned example: yesterday 1 Material Number was missing in 1 out of 100 Purchase Req and today 1 out of 1. According to Transformation Center logic it wil be (1% + 100%) / 2 However it fact yesterday we had more Purchase Req. Other than that there are lot's of performance issues as well. If you click on a created KPI it jumps to the all Objectives. But the feature itself is good for the upper Management and Process Management.
Sverre Klein
Thanks @janpeter.van.d, I changed this in my original response. 😎
  • Mar 4, 2024 4:16 PM UTC
THANK YOU AGAIN! IT WORKED LAST Question! I am now trying to apply a filter to the KPI but when I add the Vendor filter it errors out. Any idea what I am doing wrong?
Date: FILTER "EBAN"."BADAT" > TO_DATE ('2024-02-23' ,FORMAT ( '%Y-%m-%d' ))
Vendor: FILTER "EBAN"."FLIEF" = ('0010009689','0010007548','0010009755‘)
  • Mar 4, 2024 4:17 PM UTC
Thank You for taking the time out to review as well @janpeter.van.d
Sverre Klein
Hi @richanda.wrigh,
Great to hear to first question is resolved. 🙂
For your filter, I think there are two main issues.
  • First, you want to add two filters on the KPI without using a logical AND.
  • Second, you don't have an 'IN' predicator for the Vendor filter.
  • Third (not sure if it causes problems), you miss an ';' at the end of your filter statement
Try the following:
FILTER  "EBAN"."BADAT" > TO_DATE ('2024-02-23' ,FORMAT ( '%Y-%m-%d' )) AND "EBAN"."FLIEF" IN ('0010009689','0010007548','0010009755‘);
Let me know if this worked for you. 😄
  • Mar 4, 2024 11:00 PM UTC
Thanks, for some reason, it's not liking my date filter. Even when I apply the data filer by itself.
Sverre Klein
Hi @richanda.wrigh,
Is there no value returned? Could you share a screenshot of your KPI configuration in Transformation Center?
  • Mar 5, 2024 4:06 PM UTC
No there is no returned valueCapture.PNG2
  • Mar 5, 2024 4:29 PM UTC
Hello @sverre.klein11 I think I fixed it. I tried to add each vendor to the line and that seemed to work which is weird
FILTER "EBAN"."FLIEF" = '0010009689';
FILTER "EBAN"."FLIEF" = '0010007548';
FILTER "EBAN"."FLIEF" = '0010009755';
Capture.PNG2
Sverre Klein
  • Level 10
  • Answer
  • Mar 5, 2024 5:02 PM UTC
Hi @richanda.wrigh,
Try this
Sverre Klein
  • Mar 5, 2024 5:12 PM UTC
THANK YOU SO MUCH! It worked. I really do appreciate all the time you have spent to help me figure this out. Have a good day
