Time interval between 2 activities
  • May 7, 2024 9:31 AM UTC
  • 332 views
steven.bernd
Level 6
Hello everyone, I am currently calculating the time interval between 2 activities for my department, see formula...
TRIMMED_MEAN(CALC_THROUGHPUT(FIRST_OCCURRENCE['toPAS: QT5.2 - Check successful'] TO FIRST_OCCURRENCE['XI release'], REMAP_TIMESTAMPS("T_CEL_AT_HP5"."EVENTTIME", DAYS, MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY)), 5, 5)
Now it can and may also be the case that the activities are swapped, how can I then incorporate this option into the formula?
OR
TRIMMED_MEAN(CALC_THROUGHPUT(FIRST_OCCURRENCE['XI release'] TO FIRST_OCCURRENCE['toPAS: QT5.2 - check successful'], REMAP_TIMESTAMPS("T_CEL_AT_HP5"."EVENTTIME", DAYS, MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY)), 5, 5)
This formula clarifies what I want, but it doesn't work.
Maybe someone can help me.
Thanks
Best answer by dennis.pflug
Ok got it.
I think it should work like this:
TRIMMED_MEAN(CASE WHEN PU_FIRST("CASE_TABLE","T_CEL_AT_HP5"."EVENTTIME", "T_CEL_AT_HP5"."EVENTTIME"."ACTIVITY_EN" = 'toPAS: QT5.2 - Check successful') < PU_FIRST("CASE_TABLE","T_CEL_AT_HP5"."EVENTTIME", "T_CEL_AT_HP5"."ACTIVITY_EN" = 'XI release') THEN
(CALC_THROUGHPUT(FIRST_OCCURRENCE['toPAS: QT5.2 - Check successful'] TO FIRST_OCCURRENCE['XI release'], REMAP_TIMESTAMPS("T_CEL_AT_HP5"."EVENTTIME", DAYS, MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY)))
ELSE
(CALC_THROUGHPUT(FIRST_OCCURRENCE['XI released'] TO FIRST_OCCURRENCE['toPAS: QT5.2 - Check successful'], REMAP_TIMESTAMPS("T_CEL_AT_HP5"."EVENTTIME", DAYS, MONDAY TUESDAY WEDNESDAY THURSDAY FRIDAY)))
END,5,5)
BR
Dennis
dennis.pflug
Hi Steven,
who and how will it be decided to swap the activitiesis?
Why are you not using two different components? One showing the time interval from toPAS: QT5.2 - Check successful to XI release and the other one from XI release to toPAS: QT5.2 - Check successul?
BR
Dennis
steven.bernd
Level 6
  • Level 6
  • May 8, 2024 11:36 AM UTC
Thanks for your answer, the order of the activities actually doesn't matter, it's important that the time gap between the two activities doesn't become too large. I didn't want to have 2 KPIs displayed, depending on which activity occurs first. I would like to have this either or test integrated into a KPI.
Steven
dennis.pflug
  • Level 10
  • Answer
  • May 8, 2024 12:04 PM UTC
Ok got it.
ELSE
END,5,5)
BR
Dennis
steven.bernd
Level 6
  • Level 6
  • May 13, 2024 8:01 AM UTC
the formula works perfectly. Thank you for that
