Through put time each rework loop using Minutes_Between(Source , Target)
  • Jul 12, 2023 1:48 PM UTC
  • 127 views
I am trying to calculate the throughput time of each rework loop using Source- Target and failed due to no-common table errrors. My code is like below:
Minute_Betwen(
Source("_CEL_O2C_ACTIVITIES"."EVENTTIME", remap_values("_CEL_O2C_ACTIVITIES"."CHANGED_TO", ['ZA','ZA'], Null)),
Target("_CEL_O2C_ACTIVITIES"."EVENTTIME",
remap_values ( "_CEL_O2C_ACTIVITIES"."CHANGED_FROM" , ['ZA','ZA'], Null))
I got the errors that no common table found since both Activity table and temporary table for Souce/Target are N side.
Do you have any ideas how to work around this?
  • Jul 14, 2023 7:21 AM UTC
Just a shot in the dark, no idea if it will work... what if you use a PU function to put the case table in between? Like for target getting a PU_LAST(CASE, ACTIVITIES.EVENTIME)
Again, it is just a wild idea. Have luck!
  • Jul 14, 2023 7:49 AM UTC
Thanks, @Guillermo Gost: I am afraid that such PU functions will take into account only either last or first time of rework. If a case has entered and left a loop for more than 2 times, it cannot catch how long it took for the case to leave the loop at the nth time of rework.
I actually used datediff in combination with filter_to_ null for this case. It worked but the filter_to_null harms the query performance. So, Im trying to find a smarter way of doing this.
mallik.koruk11
Level 6
Forum|alt.badge.img+10
If you are using same table, in both source & target table then consider using DOMAIN TABLE and then apply PU function on it.
