Tech info on how works the pql.PQLColumn() function of Python for Celonis?
  • Jan 5, 2023 4:49 PM UTC
  • 181 views
luis.carra12
Level 2
Forum|alt.badge.img+14
Hi, all.
I need to know how works the pql.PQLColumn() function of Python for Celonis.
Does anybody knows where is the technical documentation?
I've tried https://celonis.github.io/pycelonis/1.7.6/ , and docs.celonis.com but is not enough.
In this case I need to know how to use the format argument.
Thanks!
PD.
I've found only this short info when hovering over the function in the VS Code editor
(class) PQLColumn(query: str = None, name: str = "Unnamed column", format: str = None, sorting_index: str | int = None, sorting_direction: str = None, not_included: bool = False)
A PQL Column dictionary that can be added to a PQL query statement. Behaves like dict. Corresponds to Dimension and KPI in Celonis.
Args:
    query: The PQL query of the column (KPI or Dimension).
    name: The name of te column.
    format: The formatting of the column.
    sorting_index: The sorting index of the column in a table (starts at 0).
    sorting_direction: The sorting direction. One of [ASC, DESC].
  • Jan 9, 2023 2:46 PM UTC
https://celonis.github.io/pycelonis/2.0.0/reference/pycelonis/pql/pql/
and here you can find one example
https://celonis.github.io/pycelonis/2.0.0/tutorials/executed/03_studio/01_intro_studio/#53-knowledge-models
think on it like adding columns to an OLAP table.
"format" seems to be from a previous version, now you have pql_formatter
https://celonis.github.io/pycelonis/2.0.0/reference/pycelonis/pql/pql_formatter/
(Although it is just easier to use the native conversion fucntions of python, IMHO)
HTH
luis.carra12
Level 2
  • Level 2
  • Jan 9, 2023 4:59 PM UTC
Thanks, Guillermo. I'll try it.
Luis
