Team,I used ABAP script to extract data from SAP s4/HANA system and extracted data.While execution of the transformation script: Add Activity: Record Goods IssueERROR: Column VBFA_GI.ERDAT does not exit.
  • Nov 9, 2023 10:39 AM UTC
  • 192 views
Please clarify why column ERDAT is not included in standard ABAP script but it is selected in standard transport script.
1)     Add Activity: Record Goods Issue-- ERROR: Column VBFA_GI.ERDAT does not exist.
  CAST("VBFA_GI"."ERDAT" AS DATE) + CAST("VBFA_GI"."ERZET" AS TIME) AS "EVENTTIME"
                 INSERT INTO "_CEL_AR_VBFA_ACTIVITIES FROM VBAK, VBFA, LIPS, LIKP, VBFA, VBFA, VBRP, VBRK, AR_BKPF_BSEG, USR02, MATDOC
Table Name(VBFA): Sales Document Flow
ERDAT: Date on Which Record Was Created
ERZET: Entry time
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
Are you sure you try get a correct table? I can see that script tries to get ERDAT column from VBFA_GI which seems not to exists as standard SAP table (at least according to LeanX) - maybe change it to get it from VBFA? In the bottom I can see you mention table VBFA not VBFA_GI.
ERDAT is very basic column there and it should exist for sure!
Mateusz Dudek
  • Nov 13, 2023 7:51 AM UTC
First of all Thank for the reply!!
Here VBFA_GI is an alias used for VBFA table. Below is the complete script.
INSERT INTO "_CEL_AR_VBFA_ACTIVITIES" (
    "_CASE_KEY"
    ,"ACTIVITY_DE"
    ,"ACTIVITY_EN"
    ,"EVENTTIME"
    ,"USER_NAME"
    ,"USER_TYPE"
    ,"_SORTING"
    ,"MANDT"
  ,"BUKRS"
  ,"BELNR"
  ,"GJAHR"
  ,"BUZEI"
    ,"TRANSACTION_CODE"
    ,"_ACTIVITY_KEY")
SELECT DISTINCT
    B._CASE_KEY AS "_CASE_KEY"
    ,'Erfasse Warenausgang' AS "ACTIVITY_DE"
    ,'Record Goods Issue' AS "ACTIVITY_EN"
    ,CAST("VBFA_GI"."ERDAT" AS DATE) + CAST("VBFA_GI"."ERZET" AS TIME) AS "EVENTTIME"
    ,LIKP.ERNAM AS "USER_NAME"
    ,USR02.USTYP AS "USER_TYPE"
    ,100 AS "_SORTING"
    ,B.MANDT AS "MANDT"
    ,B.BUKRS AS "BUKRS"
    ,B.BELNR AS "BELNR"
    ,B.GJAHR AS "GJAHR"
    ,B.BUZEI AS "BUZEI"
    ,"MKPF"."TCODE2" AS "TRANSACTION_CODE"
    ,B."MANDT" || B."BUKRS" || B."BELNR" || B."GJAHR" AS "_ACTIVITY_KEY"
FROM VBAK AS VBAK
    INNER JOIN VBAP AS VBAP ON 1=1
        AND VBAK.MANDT = VBAP.MANDT
        AND VBAK.VBELN = VBAP.VBELN
    INNER JOIN VBFA AS VBFA_LIPS ON 1=1
        AND VBAP.MANDT = VBFA_LIPS.MANDT
        AND VBAP.VBELN = VBFA_LIPS.VBELV
        AND VBAP.POSNR = VBFA_LIPS.POSNV
    INNER JOIN LIPS AS LIPS ON 1=1
        AND VBFA_LIPS.MANDT = LIPS.MANDT
        AND VBFA_LIPS.VBELN = LIPS.VBELN
        AND VBFA_LIPS.POSNN = LIPS.POSNR
    INNER JOIN LIKP AS LIKP ON 1=1
        AND LIPS.MANDT = LIKP.MANDT
        AND LIPS.VBELN = LIKP.VBELN
    INNER JOIN VBFA AS VBFA_GI ON 1=1  --GH added to make the GR aligned with the O2C SCRIPT
        AND LIPS.MANDT = VBFA_GI.MANDT
        AND LIPS.VBELN = VBFA_GI.VBELV
        AND LIPS.POSNR = VBFA_GI.POSNV
    INNER JOIN VBFA AS VBFA_VBRP ON 1=1
        AND VBAP.MANDT = VBFA_VBRP.MANDT
        AND VBAP.VBELN = VBFA_VBRP.VBELV
        AND VBAP.POSNR = VBFA_VBRP.POSNV
    INNER JOIN VBRP AS VBRP ON 1=1
        AND VBFA_VBRP.MANDT = VBRP.MANDT
        AND VBFA_VBRP.VBELN = VBRP.VBELN
        AND VBFA_VBRP.POSNN = VBRP.POSNR
    INNER JOIN VBRK AS VBRK ON 1=1
        AND VBRP.MANDT = VBRK.MANDT
        AND VBRP.VBELN = VBRK.VBELN
    INNER JOIN AR_BKPF_BSEG AS B ON 1=1
        AND VBRK.MANDT = B.MANDT
        AND VBRK.VBELN = B.AWKEY
       AND B.AWTYP = 'VBRK'
    LEFT JOIN USR02 AS USR02 ON 1=1
        AND LIKP.MANDT = USR02.MANDT
        AND LIKP.ERNAM = USR02.BNAME
    LEFT JOIN MATDOC AS MKPF ON 1=1
        AND VBFA_GI.MANDT = MKPF.MANDT
        AND VBFA_GI.VBELN = MKPF.MBLNR
        AND VBFA_GI.MJAHR = MKPF.MJAHR
WHERE 1=1
    AND LIKP.LFDAT IS NOT NULL
    AND VBAK.VBTYP = 'C'
    AND VBFA_GI.VBTYP_N = 'R';
Regards,
Bhupendra
