Table KPIs with parameters in views doesn't seem to work
  • Oct 11, 2023 10:09 AM UTC
  • 157 views
With kpiParams I should be able to give it's parameters (in this case a view variable) but I just get that error
imageimageSame sintax with a kpi list works fine
Same table inside an analysis works fine too
Hi Miguel, thank you for reaching out. This issue usually occurs when the Ids are names anything other than p1, p2, p3 etc. For instance on the PQL formula the ID refererring to the ID of the KPI parameter is not the same (on the PQL formula is ‘p1' and the ID on the KPI parameter is 'meses_desplazamiento’). Can you try to update it there also and let me know if this fixes your issue? Thanks and Best Regards, Blenda
  • Oct 30, 2023 11:59 AM UTC
Hi Blenda,
It works like this:
KM KPIParam ID = p1
YAML -id: = p1
It doesn't work like this:
KM KPIParam ID = meses_desplazamiento
YAML -id: = p1
or
YAML -id: = meses_desplazamiento
Thanks,
hi Miguel,
This question was answered on the ticket internally. Please feel free to raise a support ticket if you need further assistance.
Thank you!
