Struggle with pushing a CSV into Data integration
  • Jun 8, 2022 8:59 AM UTC
  • 169 views
Data not visible even though I get a status 200
  • Jun 8, 2022 9:10 AM UTC
Hi Akseli,
Please check , the data uploaded must have created a table in Global Schema.
You can access/see the table under Global schema connection.
Please choose my answer as best response , if this solves your issue.
Regards
Ayan
  • Jun 8, 2022 9:14 AM UTC
Hi Ayan,
Thanks for the quick answer. Where can I find the global schema connection?
Attached my Action flow. Action flow, creating CSV and pushing it to my Data pool
  • Jun 8, 2022 9:18 AM UTC
Hi Akseli - I misunderstood your issue , I thought you are getting this issue , at the time of loading csv to Celonis.
Coming to your screenshot: Please help me to understand , how is data populated into csv ? Are you sending a prefilled csv file to next steps ? or where is the step to fetch or populate data into csv?
  • Jun 8, 2022 9:24 AM UTC
Hi Ayan,
Sure, thanks for your support.
Attached my whole action flow.
Bildschirmfoto 2022-06-08 um 11.21.47
Bildschirmfoto 2022-06-08 um 11.20.59
