STRING_SPLIT or EXPLODE() for comma separated Array
  • Apr 10, 2026 2:13 PM UTC
  • 286 views
leonardo.spina
Level 6
Hi all,
I have a column with multiple values   e.g. col_list = '21651,5615561,50615,561591' per case_key
I need to split the values in four different rows when showing an OLAP table in studio.
Some  case_keys present up to 5000 values in that column.
Thank you for your help,
Leonardo
Forum|alt.badge.img+28
Hi ​@leonardo.spina,
This is unfortunately not possible in plain PQL, since there is no iteration option.
The hard-coded option (also for future reference for other peers here) would be:
  • Using STRING_SPLIT to split your string
  • Using UNION_ALL to plot it over different rows.
The code for your example (with 4 fields) would be something like this:
UNION_ALL(
    STRING_SPLIT(“<table_field>”, ‘, ‘ , 1),
    STRING_SPLIT(“<table_field>”, ‘, ‘ , 4)
This is not scalable to up to 5000 field references, so in that case I would advice to use Python in the Machine Learning Workbench to iterate over all values and create a new table.
