Solved: How do i get the data consumption monitor to work?Currently, despite the points below, I get the error in the studio that the tables, e.g. data_consumption_events, can not be found.
  • Jan 28, 2022 10:10 AM UTC
  • 100 views
Hi everyone,
I'm new on this topic, therefore possibly a not so solid question. ;-)
Can it be a problem with permissions or did I miss a point?
  • I have downloaded and installed the data consumption/pipeline monitor from the EMS store.
  • APC calculation has taken place after serveral days
  • I followed the instructions in the help center (activating monitoring, looking at problems with bug)
  • activated "Eventlog automerge" in all three data models / also tried without activated automerge
  • Data jobs for Data Consumption Monitoring & Data Pipeline Monitoring (Transformation/Data Load) successful executed (= green)
  • Data model was loaded according to log
Thanks in advance
Jens
Hello Jens,
As I've check all transformations of "Data Consumption Monitoring" the only used table is "data_consumption_updated_event". Try to check where the "data_consumption_events" is located and update the name.
Table should be done automatically so if you cannot find it, after couple of days, contact with Celonis guys via Customer Support :)
Let me know if that helped, maybe someone didn't update the consumption/pipeline monitor but changed the table names?
Mateusz Dudek
  • Level 1
  • Jan 31, 2022 10:27 AM UTC
Hello Jens,
Mateusz Dudek
Hi Mateusz
i found the error. the data model in the studio was assigned to the wrong data pool (not to the monitoring data pool).... now everything works.👍
Thanks anyway for your feedback :)
Bye
Jens
