Solution Professional Exam_Demo
  • Feb 15, 2022 9:24 AM UTC
  • 62 views
Forum|alt.badge.img+10
Hi all,
May I ask for the examination of Solution Professional, we need to submit a Demo for the last test of the certification, right? Is the Demo created by myself? And have to record my screen and explanation on the Demo, then submit the Video file to the system?
​Thanks and Best regards
Forum|alt.badge.img+14
  • Level 1
  • Feb 16, 2022 5:57 PM UTC
Yes that is correct - you have to create it - please capture your screen video while you are talking about it. I used Zoom - please make sure you click on Start recording option before you start your meeting. Once meeting ends please save the video and share on the dropbox provided.
Hope this helps! All the best.
  • Level 3
  • Feb 21, 2022 1:54 AM UTC
Hi, thanks for your answer, will try it.
