Simulation
  • Apr 20, 2022 6:44 AM UTC
  • 103 views
Forum|alt.badge.img+14
When creating the simulation, the following question came up with me.
Could you please answer the questions?
1:When setting up Degital Twin, should I enter actual business hours for the From and To fields of Incoming Cases? Or, should I set the time when the process is running as configured in Degital Twin?
2:When setting up Degital Twin, what does the Incoming Cases case per day value mean?
3:When creating a Simulation scenario, is it sufficient to enter actual business hours in the From and To fields of Incoming Cases? Or should I set the time when the process is actually running?
4:​When creating a Simulation scenario, what does the value of Case per day in Incoming Cases mean?
Hi Eri, thanks for reaching out. We have this help page regarding Process Simulation: Digital Twin Extraction: https://help.celonis.cloud/help/display/CIBC/Digital+Twin+Extraction Can you please check it and let us know if it helps with your questions? Best Regards, Blenda
  • Level 6
  • May 17, 2022 1:23 AM UTC
Thank you for sharing the URL.
