Show values using "Abbreviated format" is showing different ways
  • Dec 18, 2021 1:41 PM UTC
  • 87 views
Hi everyone!
When I using format values using "Abbreviated format" is showing different way. Some users see correctly with "M", "B", "K". But some users see like "millions", "billions", etc. Did you guys facing that problem? I need to all user could see the Abbreviated format correctly, like "M", "B", "K".
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Dec 27, 2021 1:21 PM UTC
Hi @Claudio Tatiyama ,
I'm not sure but I have two guesses:
  • guess #1 is that it depends on the screen resolution, with higher resolutions having more space, resulting in 'milhoes'/'millions', and smaller screens showing 'M' etc.
  • guess #2 is that Celonis uses local settings of users such as language and formatting preferences, passed through via the browser
Curious to hear if any of these 2 guesses helps!
Forum|alt.badge.img+7
Hi @joos.buijs how are you?
I appreciate your help. I have trying to contact the user that report this problem, then she told me the problem no occurs anymore. Unfourtunatelly I didn't know what's the reason of this problem.
Thank you!
