Setting up live connection with Informatica
  • Aug 23, 2024 8:12 AM UTC
  • 177 views
shayan.sarka12
Level 1
Hi Celopeers,
I would like to set-up a live connection with Informatica for fetching data for Celonis. What would be the best way to go about it?
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
Usually it's pretty straightforward:
  1. Check if there's standard connector (Probably not)
  2. Check if there's REST API / OData to get the data
  3. Try to use option to build custom extractor using custom extractor builder in Data Integration module
  4. If for any reason you're missing a option to fully utilise that API (f.e. authorization requires series of requests to first get auth token) or don't like it (like me) - just write your own. You can prototype in Postman (Postman: The Complete Guide - REST API Testing | Udemy) and autogenerate python code, to be used in ML workbench along with PyCelonis / Data Push API.
With that case, as it's "Intelligent Data Management cloud" you can also make it the other way around, utilising only Data Push API and using that platform - up to you.
Link: Cloud API and Application Integration | Informatica
Link2: Data Upload - PyCelonis
Link3: Getting Started (celonis.com)
Mateusz Dudek
