Segregation of Duties
  • Dec 18, 2021 8:34 AM UTC
  • 68 views
I want perform dual control test on segregation of duties where two activities A, B have been performed multiple times and i wish to flag the cases where they have been performed by a single user.
Activity A -> Activity B then if A is performed again then it should be followed by B from a different user. is there a way to flag these multiple times per case id
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Dec 27, 2021 1:26 PM UTC
Hi @1460056708 ,
I believe SOURCE and TARGET operators are your solution here.
It might also help to search CeloPeers, as segregation of duties (/ 4 eyes) has been discussed before, as well as SOURCE and TARGET operators.
Good luck!
