Search for spezific Activity
  • Aug 10, 2021 1:42 PM UTC
  • 90 views
Hello all,
I'm looking for a way to search for certain activities without having to show all the variations and then read over them with my eye.
An example from P2P process:
I search "Delete Purchase Order Item". But I don't know from which variant it becomes visible in the explorer. How can I search/find something like that?
Best answer by .146001171
Hello, @1460047588 ,
You can do it with the Selections. Click on "Add new selection" (on the top bar, to the right of the info on the number of cases), then on "Activity Selection". Then, on "Case Flows Through" add your activity.
I hope this helps :)
  • Level 6
  • Answer
  • Aug 10, 2021 2:30 PM UTC
