Scroller bar for charts in Views
  • May 30, 2023 10:03 AM UTC
  • 142 views
Hi all,
I would like to know if there is any option to enable scroller bar within a chart in views.
PFB screenshot for reference.
Thank you in advance :)
Shravya B
kailash.potha12
Hi Shravya, You can create that particular chart as a view and call the view in the specific section that you are interested to have it.
  • Level 6
  • Jun 8, 2023 12:33 PM UTC
Hi @kailash.potha12 ,
Thank you so much for answering my question. Your suggestion works for me. But the only problem i had was that the legend is always positioned below . PFB screenshot for your reference. Whenever i use the above mentioned approach, I would need to scroll down to see the legend details. And, unfortunately, i am not aware of any setting to change the label positioning :( .
image image In any case, you answer is much appreciated 😀
Shravya B.
