Scroll Bar to increase activities is not appearing within process explorer when I embed it inside Views. Can you suggest what i might be missing ?
  • Apr 4, 2023 12:29 PM UTC
  • 107 views
Dear all, I am trying to embed process explorer inside views to create my analysis. But The scroll bar to increase activities and links is not appearing . Could you suggest any work around . Attaching my snapshot for you for reference
Hi @1461976418 ,
You can change the YAML code for Process Explorer as shown below to get the slider bar.
 graphControls: sliders
 YAML codeThank you :)
Shravya B
  • Apr 5, 2023 4:58 AM UTC
Thank you Shravya
