Screenshot 2021-06-24 at 13.53.33
  • Jun 29, 2021 5:45 AM UTC
  • 22 views
lars.reink
Masterplan
While CoEs are the key accelerator to drive success, daily work might drag you too much into process- and technical discussions. In order to drive sustainable Value a CoE should keep an eye on five complementary streams. The following one pager can be used as template for discussing and managing all relevant streams.
Hope it helps, keen to get your views
