Scheduling Studio Skills
  • Aug 5, 2021 10:06 AM UTC
  • 108 views
Hello everyone,
I wonder that when I create a skill with Manual Sensor, can i schedule trigger of this skill ? For example I want to trigger this skill once in a month automatically . If I can't is there any differenw way to do that
Ekran AlıntısıThank you
Hi @Ugurcan Aydemir,
If you have access to the Action Flows, you can use this to schedule Automation Skills. Please follow these steps:
  • Create a new Action Flow in Studio
af1
  • Add the Celonis 'Execute Process Automation Skill' component
af2
  • After setting all the needed paramaters, save the flow. In the view-modus, you can set a schedule at the preferred day of the month.
af3
For more information, please see the documentation at https://help.celonis.cloud/help/x/2gMGAw .
Forum|alt.badge.img+27
af1
af2
af3
It works, thank you very much!
Ugurcan
