SAP On-Prem Extractor with SNC Setup
  • Nov 1, 2023 9:37 AM UTC
  • 188 views
Dear Celopeers,
We have an SAP On-Prem extractor which make RFC calls with multiple SAP systems within our organization.
We want to now add a new connection/SAP System but the connection has to be SNC. We already have the instructions for setting up SNC, but the question is
Is it possible to use the same extractor and configure so that only one system needs an SNC and others work without those server certificates?
Or If we want to add a new connection/system with SNC setup
either we must have the server certificates imported for all the existing systems or we we should have a separate extractor with SNC?
How does this work? To clarify, only system 3 in the picture needs an SNC.
Best answer by dennis.pflug
yes it is possible to just use SNC for SAP System 3 and still connect to the other SAP systems without SNC.
In order to use SNC you first have to create your own PSE file that must be imported into SAP System 3 and than you have to import the PSE files coming from SAP into your on prem Extractor environment.
After setup has been done you are activating SNC for your data connection to SAP System 3 by activating "Use SNC" within your connection settings + you need to enter the SNC Partner Name.
For the other two data connections you do not activate "Use SNC" and keep them as they are.
This should not have any impact on them.
BR
Dennis
dennis.pflug
  • Level 10
  • Answer
  • Nov 2, 2023 1:58 PM UTC
BR
Dennis
  • Nov 2, 2023 4:11 PM UTC
Hi Dennis,
Thank you for the clarification.
Sooraj
