Rework Purchase Requisition
  • Nov 29, 2023 5:50 PM UTC
  • 78 views
Hello everyone, could you tell me if there is a formula in PQL where I can get the top 1 activities of a document?
Example, the Purchase Requisition, had several repetitive reworks, I would like to pick the top 1 rework.
Forum|alt.badge.img+28
Hi @douglas.henri,
The function that will help you is INDEX_ACTIVITY_TYPE (celonis.com), but you need some steps to get the result that you want.
  1. Use the INDEX_ACTIVITY_TYPE (celonis.com) to see for every activity how often it occurs. You can set a filter here to only use a subsection of your activities.
  2. Use the PU_FIRST function to get the first Activity per Case/Document
  • Add an 'Order By' statement, and sort the activities based on their occurrence. If you do this Descending, the most occurring will end-up on top, and is captured using the PU_FIRST statement.
PU_FIRST(
  CASE_TABLE()
  , ACTIVITY_COLUMN ( )
  , ORDER BY INDEX_ACTIVITY_TYPE ( ACTIVITY_COLUMN ( ) ) DESC
